First post, by firestorm
Ok, here is the problem:
The character ":" does not exist in the keymapper.
The documentation about the keymapper is zero.
Can someone tell me how to actually use the keymapper?
Reply 6 of 7, by MiniMax
Rank Moderator
Moderator
I feel exactly the same about the mapper. I have never been able to figure out how it is supposed to work.
To undo the mapping, just delete the file mapper.txt in your DOSBox folder.
_________________
Reply 7 of 7, by wd
Rank DOSBox Author
DOSBox Author
The mapper is there to swap physical keys. The problem comes in
when you don't keep that in mind, that is you want to swap characters.
This does not work, and never will. Games/dos progs work on the
lowest level with key scancodes, so that's the level where stuff can
be changed.
Another level, much higher, is the keyboard layout stuff, but this does
only work if the game supports layouts. If it just reads from port60
you can layout as much as you want, nothing will change.
