First post, by oeolycus
Hello, I searched for help on this particular problem but found none.
I have dosbox 0.70 on Ubuntu 7.04 (installed from source). I also installed Dosbox Game Launcher. Inside the dosbox shell, I cannot write a config file. I've used, per the FAQ,
config -writeconf "~/.dosbox/dosbox.conf"
and I get the error, "Can't open file ~/.dosbox/dosbox.conf"
DBGL, thankfully created its own config file, and I can run dosbox with it, but can't save any new settings. I'm new to Linux and dosbox, so maybe I made a mistake during installation? I downloaded, unpacked the tar, and followed A.I.'s guide (which seems to be down right now). Afterwards, I threw out the .tar and its extracted contents.
All help is greatly appreciated.
