First post, by Madhoax
Hello,
I searched the forum, but I haven't been able to find an answer to my problem. What I did found was a problem with directdraw that wasn't enabled, but that not seems to be my problem.
My problem:
I installed Player Manager 2 extra, the search for glory.
In dosbox I enabled the whole C drive, and the cd drive (which is E: at my laptop).
When the game has been installed (in dosbox) and I try to start the game, after the intro i get the text:
Illegal command: mode
CD not found - terminating
Program terminating!
What is the problem? I really don't know, when I look into my E drive in dosbox, it finds the cd....
I have not found a nocd crack for pm2. In the pm2.exe file this commands are shown:
@ECHO OFF
SET DOS4G=QUIET
E:
CD \
GO C:\GAMES\PM2 %1
IS there something to hack there?
Help much apreciated!
Reply 6 of 91, by Madhoax
The content is the same:
pm2.bat:
@ECHO OFF
SET DOS4G=QUIET
E:
CD \
GO C:\PM2EXTRA %1
pm2extra.bat:
@ECHO OFF
SET DOS4G=QUIET
E:
CD \
GO C:\PM2EXTRA %1
It's kinda silly because when I install the game the cd works fine in Dosbox, but when I start the game at C:\ the program cannot find it. Also at the beginning of the game a movie is played from the cd, because I notice that it begins to spin at that point, but after the movie I get the error message...
Reply 7 of 91, by Madhoax
I'm sorry, there is a E:\Go.bat
content of this one:
@echo off
SET DOS4G=QUIET
if %1X == X goto error
cd \intro
call intro %1
:loop
cd \manager
mode co80
svga %1
if errorlevel 1 goto end
cd \play
main %1
goto loop
:error
echo.
echo Please type SETUP to configure and install
echo.
goto out
:end
echo.
echo Program Terminating!
echo.
cd\
:out
Reply 8 of 91, by DosFreak
I don't think mode is a support comand in DosBox so you'll have to REM that out.
Make your games work offline
Reply 9 of 91, by Madhoax
The only line with the command "Mode" is on the cd.
By rem out you mean remove? Like in this example I found:
Open WinClean.bat with Notepad and change ('rem out') :- This line : echo >>C:\winstart.bat del winstart.bat To this : rem […]
This line :
To this :
rem echo >>C:\winstart.bat del winstart.bat
(or just delete the whole line, if you like).
I'm not sure if I can do this on cd....
Reply 10 of 91, by Madhoax
Ok,
I tried the following:
I copied the cd to my D drive, which is my normal harddisk, no CDROM. I edited the go.bat file, I adjusted this:
:loop
cd \manager
mode co80
Into this:
:loop
cd \manager
rem mode co80
Now I get this error message:
Reply 11 of 91, by MiniMax
Rank Moderator
Moderator
Or you can make one!
In DOSBox go to your C:\PM2 folder:
Z:\>C:
C:\>cd PM2
Now create a fake MODE command:
C:\>echo @rem > MODE.BAT
And finally tell DOSBox where to find the fake MODE command:
C:\>set PATH=Z:\;C:\PM2
Now start the game.
_________________
Reply 12 of 91, by Madhoax
MiniMax wrote:
Now start the game.
This seems to work, I didn't get any failure messages.
But when I start the game now, the program returns to:
E:\manager>
So the game doesn't start after the intro, but it returns to dosbox.
What I did was:
go to pm2 folder type: echo @rem mode bat Dosbox wrote: @rem mode bat type: set path=E:\;C:\pm2 Dosbox wrote: (nothing) […]
go to pm2 folder
Did I do something wrong?
Reply 13 of 91, by TeaRex
Yes, you typed
echo @rem mode bat
instead of the correct
echo @rem > mode.bat
You left out the > and the period / full stop!
tearex
Reply 14 of 91, by Madhoax
It still doesn't work, yesterday I tried without the > and then i got some feedback from dosbox, now when I type it, it says nothing.
When I start the game however, I don't get a failure message, but it returns to E:\Manager.
    38.61 KiB
    First screen
    13.45 KiB
    Second screen
Reply 15 of 91, by MiniMax
Rank Moderator
Moderator
Madhoax wrote:
What I did was:
go to pm2 folder
And you typed it wrong when you mounted the CD-ROM too. It should be
C:\>mount e e:\ -t cdrom
not
C:\>mount e e:\ -tcdrom
(What is it with young people these days? Don't they learn to read and write?)
And third, it is not recommended to use E: for your CD-drive, better use D: as in
C:\>mount D E:\ -t cdrom
(but if you do that, you will probably have to re-install the game before you can try playing it again).
And 4th, instead of doing this by hand every time, learn to edit the dosbox.conf file with Notepad, and put all the commands you need in the autoexec-section at the bottom of the dosbox.conf file (it is all explained in my neat little 60 seconds guide)
_________________
Reply 16 of 91, by ADDiCT
Sit back. Relax. Take a deep breath.
After you did that: delete all files you have installed so far. It seems there are some basic misunderstandings here. I don't have the game to test, but i noticed a few strange things from your posts. The first thing that struck me is the fact that in your first post, you quote a batchfile command with "GO C:\GAMES\PM2 %1". But in your latest screenshots, the game seems to be installed to "C:\PM2". In a post between these two, there's suddenly a "C:\PM2EXTRA" path. All this is confusing, and you have to sort out the "where is the game installed?"-stuff _before_ looking for other potential problems.
If i were you, i'd take the following steps:
- First, create a new directory for DOSBox' virtual C:\-drive. You can call this whatever you want, and it can be on any harddisk partition.
- Start DOSBox, and mount the directory you have just created as drive C:\. It would make sense to include this (and other) mount command(s) at the end of your dosbox.conf, in the "[autoexec]" section. The line should look like this:
mount c: <drive>:\<directory>
So, for example, if you have previously created a "c:\dosgames" directory, the command would be
mount c: c:\dosgames
- After these steps, you should have an empty c:\ drive in DOSBox. Now for the game itself. In your previous attempts, you had mounted c:\, and the game CD to e:\. That could be a source of trouble, because there's a "missing" drive letter. I'd simply mount the cdrom as drive d:\. To do that, type:
mount d: e:\ -t cdrom
Note there is a space between the "-t" and the "cdrom". What you did now, is that you mounted your "real" cdrom like a harddisk directory. That _might_ be a possible source of problems, but most CD-ROM games run fine like this. For now, let's just continue.
- OK, now we have, in DOSBox, the empty c:\ drive, and the d:\ drive, which is your CD-ROM. Now, switch to the d:\ drive, install the game, configure your sound settings, and try to start the game.
It is _important_ that you keep the mountings _exactly_ like they are now. Don't move any directories/files, or change any directory names. Obviously, the game inserts directory paths into the batchfiles (probably during the installation) - if these paths change, the game can no longer find the files it needs.
Some words about that "mode" command: DosFreak mentioned that the "mode" command is not supported in DOSBox. From what i can see in the batch files you've posted, that command _could_ be an internal command of the game, not the standard DOS command, but that's just a wild guess. Anyway, the batchfile will continue to execute, even if this command could not be found, or executed.
What happens now if you start the game? If you're still having troubles, there are a lot of other things you could try, but let's make this step by step. Just remember: KEEP YOUR MOUNTINGS AND DIRECTORY NAMES EXACTLY LIKE THEY WERE WHEN INSTALLING THE GAME.
Edit: MiniMax was a little faster with his post. 😀
Reply 17 of 91, by Madhoax
First of all, thanks a million for all the help! I'm really glad there are people who know computers 😁
But it still doesn't work.
I'm sorry that I gave you this idea, I have tried to solve this problem lots of times, I installed a fresh game everytime I tried some code. So when you said I should use z:\ I first used Z:\, when that didn't work I used my cdrom letter which is E:\ because I thought it was directing it to my cdrom driveletter. But thanks for the tip. 😀
    14.51 KiB
    And after the movie, I am back at the cd drive again.
    26.63 KiB
    The movie starts playing from the cd drive....
    60.27 KiB
    Game is installed, and I type the codes
    49.91 KiB
    Setup menu
    143.99 KiB
    2202 downloads
    Mounting and starting setup.exe from cd drive
Reply 18 of 91, by ADDiCT
Hmmm, that's odd... You did completely re-install the game, and not just change the setup, didn't you?
The next thing i would try is the following:
- Copy the contents of the CD to a directory of your choice
- Look for the .BAT files in that directory (this should be GO.BAT, i think), and in the directory you've installed the game
- Open these .BAT files with notepad, and delete all the the "SET DOS4G=QUIET", and the "@ECHO OFF" lines. After that small "patch", you'll be able to see the output of the batch files, and a possible DOS4GW error message, after starting the game.
- Mount the directory from step #1 exactly like you have mounted your CD before (mount d: <drive>:\<path> -t cdrom).
- Start the game.
If one of the programs that start the game doesn't clear the screen, you should see some messages from the batchfiles, and maybe a DOS4GW error message. Is there anything like that?
If there's still nothing on the screen, you could try to start the game's main executable directly, without using the batch files. To do that type the following in DOSBox:
d:
cd manager
cd play
main
If that last "main" command alone doesn't work, you can also try "main c:\pm2". From what i can see in the batch files you have posted, this seems to be the command to start the game itself.
If all of this fails, it will be hard to identify the source of the problem, without having the game. I don't have it, sorry...
Reply 19 of 91, by Madhoax
ADDiCT wrote:
- Copy the contents of the CD to a directory of your choice - Look for the .BAT files in that directory (this should be GO.BAT, […]
- Start the game.
I have not deleted the dos4g=quit and @echo off messages, but I put rem in front of it like this: rem dos4g=quit. I have read that it's the same as deleting them. And yes, in the cd folder and in the folder where the game was installed. I loaded the cd that I copied onto my harddisk as cdrom at D:\.
But it still doesn't work. See the screener....
Well... Just have to live without PM2 then. 😀
But thanks again for the trouble.
    35.09 KiB
    Failure messages after starting the game.
