Saitek P2900
First post, by CombatGold1
I have a Saitek P2900 game pad (USB). Will it work in DosBox? I couldn't get it to calibrate in games. Is there something I should change in the config?
(emulation mode is auto)
Thanks,
Adam Reece.
Reply 1 of 1, by iampiti
If it works in your host os (windows, linux) it should work on dosbox.
I have a usb gamepad and with the default dosbox config is ok. I don't know, try changing settings like cycles, cpu core and such and try with other games
And search the forum 😀
Iampiti
