DOSBox as slowdown util for w32 games
General information and assistance with DOSBox.
Postby Qbix » 2003-6-10 @ 10:47
Yesterday I wanted to relive my good old days by playing Revanant. But it went too fast and the buildin slowdown method resulted in jerky gameplay.
So i downloaded cpukiller and turbo and these resulted in jerky gameplay. (character jumps forward instead of walking and then pauses for some seconds)
My fix was starting up dosbox twice.
and the starting the game (just under windows)
then the pc was slowed down enough to play the game in a non jerky way.
I think this comes due to the way dosbox spends its time compared to the slowdown utilities. It's weird but works great!
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby HunterZ » 2003-6-10 @ 18:14
*rofl* That's pretty sad dude. Brought a 700MHz computer to its knees by emulating 2 DOS prompts? :P Are you guys sure something isn't wacked-out in DOSbox so that that part of it is hogging more CPU power than it needs?
You're perfect, yes it's true...but without me, you're only you.
User avatar
HunterZ
Postby Nicht Sehr Gut » 2003-6-11 @ 06:52
Originally posted by HunterZ [B]*rofl* That's pretty sad dude. Brought a 700MHz computer to its knees by emulating 2 DOS prompts?
Hunter, what is the deal here? Have you never heard "use the proper tool for the job"? DosBox is good for some things...VDMSound for others... You and all the other people who insist on treating them like football teams (rooting for one at the exclusion of others) just cause grief...
Having said that, I would like to see you take out "Homer J" in a Gladiatorial arena...complete with "Gamesters of Triskelion" soundtrack...
User avatar
Nicht Sehr Gut
Postby DosFreak » 2003-6-11 @ 06:57
Would it be possible to create a standalone Windows Slowdown utility from this info?
Actually DosBox is so small it doesn't really matter....heck for those old games with speed problems just stick DosBox into a batch file twice and then execute game for a shortcut....
Any reason why DosBox need's to be loaded twice? Will upping cycles remove that requirement?
User avatar
DosFreak
Postby Qbix » 2003-6-11 @ 11:16
when dosbox is running as a prompt it consumes full "screen rendering power" but no cpu cycles so increasing the cycles doesn't matter. (only more dosbox prompts with frameskip)
The power of dosbox in this case is that dosbox redraws the screen(which involves massive calculation while in textmode) at a frequency of 70 Hz/ frameskip. So it's not aggressive consuming cpu power all the time. So there is plenty off time left for other programs and somehow my win2k box schedules it perfect in comparrison to other slowdown utils
HunterZ: dive into textmode specs and see why it's so damn slow.
User avatar
Qbix
DOSBox Author
Postby HunterZ » 2003-6-11 @ 18:16
Nicht Sehr Gut wrote:Hunter, what is the deal here? Have you never heard "use the proper tool for the job"? DosBox is good for some things...VDMSound for others... You and all the other people who insist on treating them like football teams (rooting for one at the exclusion of others) just cause grief...
Huh? I don't think that VDMSound is better than DOSBox in every situation. There are a few games that I keep DOSBox around for (although I can't think of any off the top of my head). I was just commenting on how funny Qbix's use of DOSBox was in this case.
Qbix said:
[b]when dosbox is running as a prompt it consumes full "screen rendering power" but no cpu cycles so increasing the cycles doesn't matter. (only more dosbox prompts with frameskip)
WTF? "Screen rendering power"? Can you give a technical description? That just doesn't make any sense. Are you saying that you're somehow lagging the video card instead of the CPU? :confused:
User avatar
HunterZ
Postby Nicht Sehr Gut » 2003-6-12 @ 02:05
Originally posted by HunterZ [B]I don't think that VDMSound is better than DOSBox in every situation. There are a few games that I keep DOSBox around for (although I can't think of any off the top of my head). I was just commenting on how funny Qbix's use of DOSBox was in this case.
Well your reply was drenched with sarcasm about how DosBox uses resources. Obviously it needs a lot more than VMWare or VPC because its truly emulating a PC...not just a "DOS prompt".
Compared to Bochs, its blazingly fast.
User avatar
Nicht Sehr Gut
Postby Qbix » 2003-6-12 @ 04:56
Ah sorry: I mean the creation of the virtual dosbox screen from the textmode buffer. So the step->
vidmemory in dosbox(textmode) 16 color to a 640x480x32 bit sdlwindow.That step consumes a lot of cpu power. (but not all the time only at a dosbox screen update (70/fameskip Hz)
User avatar
Qbix
DOSBox Author
Return to DOSBox General
Who is online
Users browsing this forum: Google [Bot] and 3 guests
