The Prompt command
First post, by Darth Killer
Hi all 😉
Actually i'm looking for a way to use the prompt command in DosBox, because it seems the command is yet not recognized... Does anyone have any advice ?
I precise i have taken system files from a real DOS as my DosBox system files (so i can use Edit, attrib, xcopy and others) but still prompt is considered by DosBox as a wrong command... 😢
-- Darth Killer --
Reply 1 of 6, by eL_PuSHeR
Read the readme. If you want to use a real ms-dos from within DOSBox you need to boot a ms-dos disk image.
Hint -> boot & imgmount commands.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 6, by Darth Killer
Ok got it. Thanks ofr advice 😉
-- Darth Killer --
Reply 3 of 6, by ADDiCT
You could also run 4DOS inside DOSBox, that should give you enough options for changing the prompt (;
Reply 5 of 6, by Srecko
I've seen a game script which utilizes prompt to ask a question.
Except a visual change, it remains fully functional in dosbox.
Something like
echo Do you want to start a game now? (type Y or N)
prompt ?
Of course Y.bat and N.bat are in the same directory 🙄
Reply 6 of 6, by ykhwong
For the implementation of prompt command, there is function.patch that provides such feature on sourceforge page.
