First post, by arromdee3
/home/arromdee/dosbox% aplaymidi -l
Port Client name Port name
64:0 ADI SoundPort AD1816A MIDI - Raw ADI SoundPort AD1816A MIDI
65:0 OPL3 FM synth OPL3 FM Port
When I start up Dosbox, it uses port 65:0. How do I tell it to use 64:0 instead?
There is a configure file section for midi and one of the options is device. But the values for device are alsa, oss, etc. I can't find the syntax for specifying a particular Alsa port. It's not in the README, FAQ, or man page either.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
on the configline you type 64:0
mpu401=intelligent
device=default
config=64:0
Water flows down the stream
