First post, by pandarsson
I was wondering if anyone could tell me the differences between the CH Flightstick and the Thrustmaster FCS. Basically, I have a Logitech Wingman Digital Extreme 3D and am wondering which of the two I should emulate. I am currently emulating the Flightstick, but I notice that in Terminal Velocity, the twisting of the stick doesn't do anything. Now, I don't know if this is a limitation of Terminal Velocity (when I played it long ago, I had this huge contraption that attached to the desk and it didn't have such an axis) or a limitation of the CH Flightstick that perhaps the Thrustmaster did not have.
Any help would be appreciated.
Reply 1 of 2, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
ch can have 4 button 4 axis + hat
fcs can have 4 button 3 axis + hat (the 4th axis is used for hat)
You need to tell the game which joystick it is (ch or fcs).
Afaik Terminal Velocity can make use of throttle and hat (choose ch in dosbox.conf and in the game menu).
1+1=10
