First post, by Demarche
Greetings.
I'm wanting to use multiple dosbox.conf (AKA "DOSBOX Preferences") files in OSX. I know this is possible, but I'd prefer to do it without A) using terminal to start dosbox with the -conf switch, or B) using one of the front ends. Is there a way to add switches to an alias in the same way they can be added to a program shortcut in Windows?
My goal: I'm setting up multiple games for a non-technical Mac user and want to make 2-click shortcuts that mount the drive(s), swap to the proper directory, and launch the game in question without requiring the use of a front end.
EDIT: possible perhaps to create some sort of file that runs pre-set terminal commands? I just don't want to force this person to open terminal and type in it; if I could imbed an alias with commands to open DOSBOX in terminal with the -conf switch it would be great.
