First post, by stickman64
I am trying to run Wolf 3d by ID and when i do WOLF>wolf3d.exe nothing happens and i followed directions clearly. It also prevents me from writing anything! I need help, and I have Vista!
and i use dosbox too...
Reply 1 of 11, by ADDiCT
Judging by the fact that you're trying to run a DOS game under Vista, and by the silly und uninformative title of your post, you need help indeed. I'm not sure we can give you the help you really need, though.
Reply 3 of 11, by stickman64
I want to play Wolfenstein 3d but we have crappy vista. So i get dosbox and follow the intructions at http://www.dosbox.com/wiki/Basic_Setup_and_In … ation_of_DosBox
and when i write down c:\>WOLF>WOLF3D.exe it dosent run the game and wont let me write anything else. I just want to play a good game again!
Reply 7 of 11, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
PS: If you are talking about the free/shareware episode "Escape from Wolfenstein" (http://www.3drealms.com/wolf3d/), my guide should work too, if you use
mount D "folder-where-you-unpacked-the-zip-file"
instead of mounting your CD-drive.
_________________
Reply 8 of 11, by MiniMax
Rank Moderator
Moderator
Or you could download DBGL 0.60
http://home.quicknet.nl/qn/prive/blankendaalr/dbgl/
which has the shareware episode pre-installed. After installing 0.60, upgrade with the 0.62 JAR-file.
_________________
Reply 10 of 11, by MiniMax
Rank Moderator
Moderator
wd wrote:
if you care then please merge it with the doublepost
Done. Merged and did a bit of clean-up, changed the title, etc.
_________________
Reply 11 of 11, by StaVriS92
guys i dont have a cd but i installed wolfenstein correctly on my pc. and it cant start 🙁 i downloaded DOSBox and i mount my drive and changed it and when i type wolf3d.exe it freeze and i cant write. pls help me...
