First post, by jcdutton
I have problems with CAPS LOCK in DOSBOX 0.72.
On 32-bit platforms it works fine. I.e. You press CAPS LOCK and it locks.
On 64-bit platforms it does not work correctly. I.e. You press CAPS LOCK and it does not lock, but works like a SHIFT key.
I have even installed a chroot 32-bit userspace on a 64-bit platform and the CAPS LOCK works fine.
So, I conclude that the problem is 64-bit related.
Has anyone else seen this behaviour.
The test I am doing is simple.
type "dosbox" without any config file, and just type chars at the DOS prompt and press the CAPS lock on and off.
Reply 4 of 7, by jcdutton
Ok, I have done some more investigations.
Is seems that the binary dosbox that comes with ubuntu is fine, but if I try to compile my own dosbox, I have problems.
Is there any way to find out which compile options were used when ubuntu compiled dosbox?
Reply 6 of 7, by jcdutton
CAN_USE_LOCK 1
makes is work.
Just a minor bug, if dosbox is entered with the CAPS LOCK ON, the first press of CAPS LOCK in dosbox does not call the IRQ1 routine. If CAPS LOCK is OFF when dosbox in entered, the first press of CAPS LOCK works fine.
