First post, by jcdutton
I have problems with CAPS LOCK in DOSBOX 0.72.
On 32-bit platforms it works fine. I.e. You press CAPS LOCK and it locks.
On 64-bit platforms it does not work correctly. I.e. You press CAPS LOCK and it does not lock, but works like a SHIFT key.
I have even installed a chroot 32-bit userspace on a 64-bit platform and the CAPS LOCK works fine.
So, I conclude that the problem is 64-bit related.
Has anyone else seen this behaviour.
The test I am doing is simple.
type "dosbox" without any config file, and just type chars at the DOS prompt and press the CAPS lock on and off.
