Aaron H wrote:
In other words, I want my QA program to open when I click on the DOSBox icon on my desktop
and that's still another thing :
to do it you can write the .conf file you feel fit, call it my_own.conf
then run the link using the -conf my_own.conf switch
and you're done, it goes like that
pretty simple, you can prepare multiple configurations if you like 😀
Hey, there's one thing I wanted to add ever since your first post, about your Question #3:
the autoexec section makes for a perfect batch replacement to start with, doesn't it, but if you need some more afterwards, I guess you can't write a bat file in dosbox, you can't use edit.com or so afaik,
but you can prepare your tailored batch in Windows, be sure to put it in the soon to be mounted dir you choose and then you can call it from dosbox and it ought to work
(as long as you take care not to mess with the paths... 😉 )
