First post, by bubs
Is there a way to make graphics better on dosbox like you can on scummvm ?
Reply 2 of 7, by eL_PuSHeR
You will probably get lucky with some CVS build (Gullikoza or someone else). I am not sure.
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
did you check the configuration file of dosbox ?
#    scaler: Scaler used to enlarge/enhance low resolution modes. If 'forced' is appended,the scaler will be used even if the result might not be desired.
# Possible values: none, normal2x, normal3x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x
Water flows down the stream
Reply 6 of 7, by Kelly Stiver
Qbix wrote:
scaler=super2xsai forced
Does this make the gameplay (and the screenshots taken via Dosbox's Screen Capture feature as well) graphics sharper with a higher resolution?
