First post, by plutonick
I installed windows 3.1 following this excellent guide.
Windows 3.1x DOSBox Guide
and although there are specific instructions in order to install a soundblaster driver, I was thinking if it is possible to install gravis ultrasound. Somehow I see a ultrasound driver in the midi section of windows 3.1 but it is not working correctly.
Is it possible to have a GUS midi driver under windows 3.1? If yes, is there a guide somewhere you can direct me to? I did try the search function of the forum 😀
Reply 1 of 1, by plutonick
I found the answer. I am answering here in case someone ever has the same question
1. Copy your ultrasound directory from dosbox in your windows 3.1 folder [just to make sure that it's mounted when dosbox starts]
2. When in windows 3.1 [or 3.11 i suppose] go to control panel - drivers - chose add and then the first option [updated/unlisted driver].
3. navigate to your ultrasound directory, then go to windows dir, and click ok!
Done.
Then navigate to
