First post, by Sheriff Hobbes
Hi guys,
in DOSBox, is it possible to disable the mouse?
Over the weekend I installed several jump & run games. None of them supports the mouse (and in fact it would be pointless for playing), but I always see a useless mouse pointer in the game. I haven't seen any comments about this in the Readme or the config file, but maybe there a hidden option?
Hobbes
Marriage is a three ring circus:
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 2 of 10, by MiniMax
Rank Moderator
Moderator
Re: Mouse problem
_________________
Reply 3 of 10, by Sheriff Hobbes
Thanks for the link, but mouseoff.com doesn't work. Using version 0.72 under XP.
Examples of games are Commander Keen, Duke Nukem 2, Monster Bash.
It's actually a problem of DOSBox not capturing the mouse cursor when you click inside the DOSBox window. I believe this is only a problem with games not supporting the mouse, but not with all of them, e.g. the cursor disappears in Duke Nukem.
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 5 of 10, by DosFreak
or press the key combination to capture the mouse.
Try the latest CVS build of DOSBox.
Make your games work offline
Reply 6 of 10, by Sheriff Hobbes
DOSFreak is right. Ctrl+F10 does the trick. This means that the "auto lock" function does not work in these games. No big deal though, but you can add it to the bugs list. 😉
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 7 of 10, by wd
Rank DOSBox Author
DOSBox Author
Where's the bug? In windowed mode there's no reason to disable the mouse
cursor, assuming you're not too stupid to move the mouse out of the window
yourself if the sheer cursor annoys you.
Reply 9 of 10, by MiniMax
Rank Moderator
Moderator
I wasn't talking about windowed mode.
Sorry - our mistake.
