Playing DOS games in DOSBox from zip files
First post, by cabinboy46
Is it possible to configure DOSBox to play games directly from zip files like with some Gamebase databases? Most of my games are zipped for purposes of HD space saving, and it would be cool to just have DOSBoz auto-unzip an archive, play the game, then zip it back up when done. I see the zip option in the mounting window. Is there a tutorial for setting DOSBox up for zip files? TIA.
C.
Reply 1 of 5, by DosFreak
The official DOSBox doesn't support this but there is a patch to do so (you've have to add it and compile DOSBox though).
I think frontends like DFend Reloaded and DOG handle this if your copy of DOSBox doesn't support it but I haven't tried it with them.
Make your games work offline
Reply 2 of 5, by robertmo
You can make a hdd compression for that reason - no need for extra implementation into dosbox. Just make a separate hdd partition for old games (or even connect a separate hdd for them) and apply a hdd compresion for it.
And all these old games are so huge when compared to 16GB Grand Theft Auto IV for example.
And Hdds are getting smaller and more expensive all the time.
Reply 3 of 5, by MiniMax
Rank Moderator
Moderator
Why a separate partition? At least on WinXP I can opt to compress just a folder.
_________________
Reply 5 of 5, by ProDigit
Old topic, still interesting.
Disk compression compresses between 5 to 20%.
File compression like 7z, RAR, or even Winzip, compresses between 25-80%; that is uncompressed data of course.
If you're going to try to compress an MP2/3 file, JPEG, or another archive, you won't get those ratios, as the jpeg/Gif, MP2/3/4, OGG, Opus etc... file formats already are a compression format on themselves..
But text files compress really well.
Only problem I see with this, is that certain files get modified when opening them. And save files would need to be created outside of the archive, not to affect the original archive.
Keeping them in an archive, will result in you starting from zero every time you eg: play a game, or need to reset the configuration of some programs every time .
