First post, by lucky7456969
Warning 1 warning C4297: 'SDL_main' : function assumed not to throw an exception but does l:\documents and settings\garfield\my […]
Warning 1 warning C4297: 'SDL_main' : function assumed not to throw an exception but does l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\gui\sdlmain.cpp 1845 dosbox
Warning 2 warning C4297: 'SDL_main' : function assumed not to throw an exception but does l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\gui\sdlmain.cpp 1845 dosbox
Error 3 error C2628: 'Bit8u' followed by 'unsigned' is illegal (did you forget a ';'?) l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\include\regs.h 69 dosbox
Error 4 error C2628: 'Bit8u' followed by 'char' is illegal (did you forget a ';'?) l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\include\regs.h 69 dosbox
Error 5 error C3409: empty attribute block is not allowed l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\include\regs.h 69 dosbox
Error 6 error C2143: syntax error : missing ']' before 'constant' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\include\regs.h 69 dosbox
Error 7 error C2059: syntax error : 'constant' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\include\regs.h 69 dosbox
Error 8 error C2238: unexpected token(s) preceding ';' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\include\regs.h 69 dosbox
Error 9 error C2059: syntax error : '[' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 7 dosbox
Error 10 error C2039: 'cpu_regs' : is not a member of 'GenReg32' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 8 dosbox
Error 11 error C2039: 'regs' : is not a member of 'GenReg32' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 8 dosbox
Error 12 error C2059: syntax error : '[' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 8 dosbox
Error 13 error C2228: left of '.Bit8s' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 12 dosbox
Error 14 error C2146: syntax error : missing ')' before identifier 'val' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 12 dosbox
Error 15 error C2059: syntax error : ')' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 12 dosbox
Error 16 error C2143: syntax error : missing ';' before '{' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 12 dosbox
Error 17 error C2447: '{' : missing function header (old-style formal list?) l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 12 dosbox
Error 18 error C2146: syntax error : missing ')' before identifier 'val' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 23 dosbox
Error 19 error C2059: syntax error : ')' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 23 dosbox
Error 20 error C2143: syntax error : missing ';' before '{' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 23 dosbox
Error 21 error C2447: '{' : missing function header (old-style formal list?) l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 23 dosbox
Error 22 error C2146: syntax error : missing ')' before identifier 'val' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 35 dosbox
Error 23 error C2059: syntax error : ')' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 35 dosbox
Error 24 error C2143: syntax error : missing ';' before '{' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 35 dosbox
Error 25 error C2447: '{' : missing function header (old-style formal list?) l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 35 dosbox
Error 26 error C2146: syntax error : missing ')' before identifier 'val' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 47 dosbox
Error 27 error C2059: syntax error : ')' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 47 dosbox
Error 28 error C2143: syntax error : missing ';' before '{' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 47 dosbox
Error 29 error C2447: '{' : missing function header (old-style formal list?) l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 47 dosbox
Error 30 error C2146: syntax error : missing ')' before identifier 'val' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 59 dosbox
Error 31 error C2059: syntax error : ')' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 59 dosbox
Error 32 error C2143: syntax error : missing ';' before '{' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 59 dosbox
Error 33 error C2447: '{' : missing function header (old-style formal list?) l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\helpers.h 59 dosbox
Error 34 error C2146: syntax error : missing ')' before identifier 'op' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\string.h 29 dosbox
Error 35 error C2182: 'dyn_string' : illegal use of type 'void' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\string.h 29 dosbox
Error 36 error C2059: syntax error : ')' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\string.h 29 dosbox
Error 37 error C2143: syntax error : missing ';' before '{' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\string.h 29 dosbox
Error 38 error C2447: '{' : missing function header (old-style formal list?) l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\string.h 29 dosbox
Error 39 error C2146: syntax error : missing ')' before identifier 'op' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1131 dosbox
Error 40 error C2182: 'dyn_dop_ebgb' : illegal use of type 'void' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1131 dosbox
Error 41 error C2059: syntax error : ')' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1131 dosbox
Error 42 error C2143: syntax error : missing ';' before '{' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1131 dosbox
Error 43 error C2447: '{' : missing function header (old-style formal list?) l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1131 dosbox
Error 44 error C2146: syntax error : missing ')' before identifier 'op' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1155 dosbox
Error 45 error C2182: 'dyn_dop_gbeb' : illegal use of type 'void' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1155 dosbox
Error 46 error C2059: syntax error : ')' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1155 dosbox
Error 47 error C2143: syntax error : missing ';' before '{' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1155 dosbox
Error 48 error C2447: '{' : missing function header (old-style formal list?) l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1155 dosbox
Error 49 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1178 dosbox
Error 50 error C2228: left of '.mod' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1178 dosbox
Error 51 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1183 dosbox
Error 52 error C2228: left of '.rm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1183 dosbox
Error 53 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1183 dosbox
Error 54 error C2228: left of '.rm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1183 dosbox
Error 55 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1189 dosbox
Error 56 error C2228: left of '.reg' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1189 dosbox
Error 57 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1189 dosbox
Error 58 error C2228: left of '.reg' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1189 dosbox
Error 59 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1190 dosbox
Error 60 error C2228: left of '.mod' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1190 dosbox
Error 61 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1194 dosbox
Error 62 error C2228: left of '.rm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1194 dosbox
Error 63 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1194 dosbox
Error 64 error C2228: left of '.rm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1194 dosbox
Error 65 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1200 dosbox
Error 66 error C2228: left of '.reg' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1200 dosbox
Error 67 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1200 dosbox
Error 68 error C2228: left of '.reg' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1200 dosbox
Error 69 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1201 dosbox
Error 70 error C2228: left of '.mod' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1201 dosbox
Error 71 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1205 dosbox
Error 72 error C2228: left of '.rm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1205 dosbox
Error 73 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1205 dosbox
Error 74 error C2228: left of '.rm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1205 dosbox
Error 75 error C2146: syntax error : missing ')' before identifier 'op' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1209 dosbox
Error 76 error C2182: 'dyn_dop_evgv' : illegal use of type 'void' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1209 dosbox
Error 77 error C2059: syntax error : ')' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1209 dosbox
Error 78 error C2143: syntax error : missing ';' before '{' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1209 dosbox
Error 79 error C2447: '{' : missing function header (old-style formal list?) l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1209 dosbox
Error 80 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1235 dosbox
Error 81 error C2228: left of '.reg' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1235 dosbox
Error 82 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1236 dosbox
Error 83 error C2228: left of '.mod' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1236 dosbox
Error 84 error C2228: left of '.big_op' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1237 dosbox
Error 85 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1240 dosbox
Error 86 error C2228: left of '.rm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1240 dosbox
Error 87 error C2228: left of '.big_op' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1244 dosbox
Error 88 error C2228: left of '.big_op' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1245 dosbox
Error 89 error C2146: syntax error : missing ')' before identifier 'decode_fetchb' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1245 dosbox
Error 90 error C2059: syntax error : ')' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1245 dosbox
Error 91 error C2228: left of '.big_op' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1246 dosbox
Error 92 error C2146: syntax error : missing ')' before identifier 'decode_fetchw' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1246 dosbox
Error 93 error C2059: syntax error : ')' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1246 dosbox
Error 94 error C2228: left of '.big_op' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1247 dosbox
Error 95 error C2146: syntax error : missing ')' before identifier 'decode_fetchd' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1247 dosbox
Error 96 error C2059: syntax error : ')' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1247 dosbox
Error 97 error C2146: syntax error : missing ')' before identifier 'op' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1252 dosbox
Error 98 error C2182: 'dyn_dop_gvev' : illegal use of type 'void' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1252 dosbox
Error 99 error C2059: syntax error : ')' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1252 dosbox
Error 100 error C2143: syntax error : missing ';' before '{' l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1252 dosbox
Error 101 error C2447: '{' : missing function header (old-style formal list?) l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1252 dosbox
Error 102 error C2228: left of '.modrm' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1276 dosbox
Error 103 error C2228: left of '.reg' must have class/struct/union l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1276 dosbox
Error 104 fatal error C1003: error count exceeds 100; stopping compilation l:\documents and settings\garfield\my documents\downloads\dosbox-0.73\dosbox-0.73\src\cpu\core_dyn_x86\decoder.h 1276 dosbox
Error 105 error BK1506 : cannot open file '.\Debug\core_dyn_x86.sbr': No such file or directory BSCMAKE dosbox
And my second question is
Where did the authors find all the hardware specs (like VGA cards paradise s3) from the internet? I want to take a look
Thanks in advance
Jack
Reply 1 of 3, by wd
Rank DOSBox Author
DOSBox Author
How exactly are you compiling it? As it works fine with visual studio 2008 pro
out of the box.
And please post the contents of regs.h as seen in visual studio (includes directory).
Reply 2 of 3, by lucky7456969
I just put the path of various libraries under right click on project > properties
> additional libraries and additional include (SDL, SDL.net, zlib, libpng etc)
Then compiled....
The "byte8u" stuff still just kept disturbing the compilation...
I did not change anything, i use the tar ball and use the sln file straight away.
Thanks
Jack
Reply 3 of 3, by wd
Rank DOSBox Author
DOSBox Author
