First post, by Uhfgood
I'm just wondering if there's a way to change the aspect ratio of the window. Basically what i'm getting at is, i'm running King's Quest 6, and since it's in 320x200 when I run it in a window it gets "squished" because i'm using 800x600 resolution, i'm wondering if there's a way to fix this, or if DosBox creators ever plan on implementing aspect ratio adjustment?
Thanks,
Keith Weatherby II
uhfgood@artoo.net
