First post, by kconover
I am using DOSBox on a Win 7 Pro 64-bit laptop, to run HyGen, which is arguably the first hypertext program, from Neil Larson of MaxThink. I use it to take and hyperlink medical notes. I would like to be able to paste into it from Windows.
When I run DOXbox and have the following in the autoexec section:
mount C C:\notebook
C:
hygen
exit
I get two windows.
First is DOSbox Status window. If I click the top left System Window, it shows options to Edit > Paste etc.
In front of this is a window that says
DOSBox 0.74, CPU speed: 3000 cycles, Frameskip 0, Program: Hygen.
But this window's System Menu does not have an Edit option, so I cannot use this to paste into Hygen.
Is there a way to allow pasting?
Thanks for any thoughts.
