First post, by hyperion
how to resize the window for dosbox?
one of my sites http://www.francestunts.fr.st
windowed mode? you cant use custom sizes with draging. Theres the scaler option; scaler=advmame2x or normal2x. Will give double sized display and other benifits with a speed hit.
thanks replying so fast 😀
dragging?? i'll try that... my main purpose is to REDUCE it... I briefly read the conf file and saw the double size option.
just tried dragging it... it moves, but doesnt reduce or simply resize... right click on the window same problem... no resize option. Another idea?
well you should set the scaler to none
you can't get it any smaller than that. Dosbox has disabled resizing because of negative speed results when a windowed is being resized
Water flows down the stream
none? okay,
hat tip Qbix.
of course, if any succeeded in smtg, idea welcome...
