First post, by eldergamer
I would like to put DosBox on my thumb drive. This in itself isn't an issue. I can drag, drop, and use DosBox already on a thumb. What I can't do is set anything in the conf. From system to system my thumb drive changes drive letters. This plays heck with trying to automate things. For example: One of my favorite games is Scorched. What I would like to do is make a shortcut that engages DosBox and runs the game in full screen. While this is possible with a normal installed version of DosBox it's not so easy when your drive letters change from z: to g: to I: then back to z: again.
By the way these are not my machines. Just wanted to let you know that before you explain how to keep the drive letters that same by setting it on each machine. I don't have the admin rights on 2 of them. Besides my original question was about making DosBox truly portable.
Any idea's ?
Thanks
