First post, by filipetolhuizen
Has anyone noticed that? only one shift key works at a time. Both working at the same time is however, essential for playing most Pinball games. Is there a workaround for this? Forcing windib did not work for me. And yes, it's working outside DOSBox (tested on VirtualPC running Win98SE with the same game - Extreme Pinball).
Reply 1 of 8, by bloodbat
It's working fine for me
Reply 2 of 8, by robertmo
that happens with windib
Reply 3 of 8, by filipetolhuizen
BTW, I'm running the latest ykhwong's build. Are there any other settings that I should change? usescancodes did not work either. Ditto for turning NumLock on and changing keyboard layout.
Reply 4 of 8, by robertmo
set sdl_videodriver=directx
Reply 5 of 8, by filipetolhuizen
Thank you so much! That worked perfectly! Is there any way that I can set this permanently?
Reply 6 of 8, by ykhwong
You can find "Run DOSBox with DirectX driver.bat" in TOOLS directory.
Reply 8 of 8, by Gamecollector
Just run Ykhwong's dosbox with "Run dosbox with directX driver". By the way, windib isn't working with ddraw renderer, so I am using this .bat by default.
