First post, by akali01
I install DosBox, it works perfectly, than unpack dosbox.conf and russian.txt from lang archive and try running DosBox from .exe in install dir (not .lnk, without specifying any keys) and get
CONFIG: loading primary settings from config file dosbox.conf
Exit to error: MSG:can't load messages: "C:\Program Files\DOSBox-0.74\russian.txt"
I tried to place russian.txt to C:\, use no " or change \ to /, and do it on 2 systems with Vista and 7, runed under admin rights. But result is always the same 🙁 Checked sourses, but there are just fopen(...) and dosbox.conf reads without any problem. No idea what i'm doing wrong, pls help if you have any thoughts.
Reply 1 of 4, by Davros
have you edited dosbox.conf ?
find the line
language=
change to
language="C:\Program Files\DOSBox-0.74\russian.txt"
ps: russian.txt is in C:\Program Files\DOSBox-0.74\ ???
