dosbox config and Mac
First post, by Cschneider
I am trying to find the config file on the mac, but I went to Library >> preferences
I do not see a directory called DOSBox 0.74 Preferences
I tried to execute the command config -writeconf z:\dosbox.conf
I get an error stating it cannot open the file.
Reply 1 of 2, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Were you looking in /library or in ~/library? ~/library is the correct one but since OSX 10.7 it is hidden. In finder click on the menu "go to" while holding the options key and library will be there to click.
And of course the writecconf doesn't work. You have to pass a real path on your system and Z:/ doesn't exist.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 2, by Cschneider
i was able to figure out the writeconf switch. but when running DOSBOX it is supposed to create the config file in the library/preferences. I found it going that route as well.
