First post, by Guest
Dosbox allows me to play some of the older koei games such as RTK2, RTK1, Bandit kings of ancient china and so on, however, the keyboard doesn't function when I'm in combat mode. Can someone help me on this? I"m using the standard US keyboard with 103 keys, Running on windows xp and a p4 1.8ghz cpu.
Thanks,
Mike
Reply 4 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
default answer.
Hope for next version.
We don't know/have the games.
Little you can do about it.
Water flows down the stream
Reply 5 of 11, by robertmo
The problem you have is caused by Dosbox not supporting numeric keyboard (when numlock is on).
Something was explained here but it is a bit too advanced for me 😉
Re: games with num lock key
Reply 6 of 11, by gil22
I looked into this a while ago........
"Also, it looks like DOSbox. However, even though the game will tell you to use the numeric keypad to move during battle, I had to use the top row number keys."
-I don't remember which keys did what though, so try them all....
Good Luck!
