First post, by Godzuki Remembers
"unable to change to: omf" yeah im at that part......omf is the folder that the game is in and I try to make it say C:\omf>omf.exe and then it will work but when I type
C:\>cd omf
can anyone help?
Reply 1 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
if you do [dir]
do you see the directory omf there ?
how did you mount your c drive ?
Water flows down the stream
Reply 11 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
you actually should blame the developpers by not making it clear that you should read the documentation
Maybe some exit if people don't read it 😀 Like in eggdrops 😀
Reply 15 of 16, by Zup
What if they put a message in the program?
"Please press the key hidden into the documentacion to continue..."
I guess it would be done only the first time you install the program (to avoid stressing users)... at least they must read the docs UNTIL they find the key (don't put it on the last page, it seems so obvious...).
