DOSBox problems with resolution when EXITING full screen
First post, by greewn
Hi everybody, I just installed DOSBox on my Ubuntu 12 system and everything seems to be running fine except for one thing. After going full screen on DOSBox the resolution changes automatically to fit the full screen (with no problem whatsoever) and the program I am running runs perfectly.
The problem happens when I exit full screen or when I close DOSBox. The resolution doesn't revert to my original, pre-fullscreen, Ubuntu resolution.
Please advice and thank you for your help 😜
Reply 5 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
LibSDL.org is what SDL is and Dosbox is using that as well as other projects like ScummVM or Exult...
Try those or see if you find some bug report about your distro, libsdl 1.2.15 and fullscreen
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 8, by JENKS
I had the same problem with Ubuntu 12.04 LTS and DOSBox.
I changed my dosbox-74.conf file configuration settings to this:
fullscreen=false
fulldouble=false
fullresolution=1600x900
windowresolution=original
output=overlay
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-0.74.map
usescancodes=true
I changed the setting fullresolution=1600x900 to reflect the ubuntu desktop settings. Then changed the setting to output=overlay.
Basically, you need to set the fullresolution= to the ubuntu screen resolution that your using on your desktop outside of dosbox.
Now you can <ALT-ENTER> back and forth with no video screen screw ups.
