First post, by Guest
DOSbox 0.60 allows a 386 to be emulated. How can I then set it to 286-mode?
I'd like to test a few DOS programs if they behave correctly on 286-systems without having one myself.
Or do I need an older dosbox version that does not have 386-emulation?
is there an entry in the config-file for this?
speed is not important, cpu architecture is.
