First post, by f00dl3
Not seeing any good answers to this and have been struggling with this all day - was wondering if anyone had any ideas on how to get a problem solved here. Got DOSBox Turbo for my Android and got a bunch of games working great on it as well as Windows 3.11 w/ some old apps. Decided I want to try to off-load the Win 3.x/DOS stuff to a .IMG file so I can put Windows 95 or 98 in an IMG as well and run it there for the heck of it.
So here's the problem - created a file called W3X.IMG and for thrills, W3XL.IMG - the W3XL one is a 1 GB image for the DOS/Win 3.11 stuff, while the W3X is a 512 MB one since I heard somewhere DOS Box has issues with over 512 MBs. I have 328 MBs of data to off-load into that image from games/etc.
I was able to create the image and mount the images using the
imgmount 2 /sdcard/DOS/W3XL.IMG -size 512,63,16,2080 -t hdd -fs none
(or)
imgmount 2 /sdcard/DOS/W3X.IMG -size 512,63,16,1040 -t hdd -fs none
In both cases, DOSBox Turbo states the image is successfully mounted.
I then use the 622 boot disk to run FDISK
boot /sdcard/DOS/622.IMG
It loads into the DOS 6.22 Boot shell, but it states No drives found. When I attempt to do an FDISK it shows the primary partition 1, I select that, and it locks up when asking for reboot.
Additionally, when trying this again after already FDISK'ing the IMG file, it states No partitions defined, and when I selected not to use all the free space it only showed me as having 16 MBs to work with - WTH?
I then do the 2nd part of the process:
imgmount c /sdcard/DOS/W3XL.IMG -size 512,63,16,2080
States Drive C successfully mounted in DOS Box Turbo
I then go back into 622 boot disk - and try the format C: command.
No drives show up assigned to C: - it also states No drives are available.
Any ideas how to get the DOS 6.22 Boot disk to recognize the mounted C drive in DOS Box Turbo?
I've also tried to force the "boot" command to think I have both drives mounted by doing
boot /sdcard/dos/622.img /sdcard/dos/w3xl.img -l a
but it doesn't do any good.
