First post, by nemesis855
I'm a relative newbie to both DosBox and Linux. Running DosBox 0.74 under Lubuntu 12.1. Running on a Pentium 4 with 2GB memory.
I was able to sucessfully mount the physical floppy drive at A:. I inserted a floppy and got it to recognize disk contents and install a program in my DosBox 'drive c'. The issue I'm having is when I insert a second floppy and do a directory of the disk, I see the contents of the first disk !? The same result occurs when I removed all disks. I got the same result when I unmounted and re-mounted the floppy.
Anybody run into this behavior before and is there a 'fix'? Thanks.
JohnnyD
