First post, by Dark_Oppressor
I've been using D-Fend Reloaded on my Windows machines for a long time, but I've got a Linux machine now and I wanted a native DosBox frontend. DBGL looks good, but I'm wonder if there is a way to migrate my D-Fend Reloaded profiles over, as I have a ton of games setup. Is this possible/easy?
Reply 1 of 2, by rcblanke
Unfortunately, I don't believe this is possible at the moment. Although DFR can import DBGL gamepackarchives, it cannot create them as far as I know. I don't know if Alexander is planning on adding such a feature, but if not, I might come up with a way to import DFR data into DBGL like I did with the original D-Fend data importer. This may take a while to implement though, as it seems the data in DFR is structured quite differently from the original, and is also quite a bit more complex...
Reply 2 of 2, by Dark_Oppressor
Rats, I was afraid that was the case. I saw the Import Dfend profile option but nothing about Reloaded, and wasn't sure if their profiles were the same. Well, thanks for the response!
