First post, by akkkarki
Hello!
I've just started to use DOSBox nowadays, so I'm a newbie. My problem is that if I change the windowresolution tag in the dosbox-0.74.conf file to 1024x768 (and the output tag to ddraw), it'll resize the dosbox window, but also the content of it, so that I've got some big characters in a very bad resolution. If I put fullscreen tag to true, it does the same, with the difference that it will open in fullscree, of course. I haven't got any idea what to do, it's only a "blank" dosbox window, I haven't even tried to run any games on it yet. I hope somebody could help...
Thanks in advance:
akkkarki
Reply 2 of 3, by akkkarki
Meanwhile I've tried to run a Windows 3.1, because a friend of mine said it's working great for him. (I know that DosBox is for games, but he said it runs perfectly.) And yes, it is really working, but the previous problem stayed: if I give win a program as a parameter (win myprg.exe), it will open, but I can't see the top and the bottom of the program's window, because it's out of DosBox's window. (My friend managed DosBox to show the program correctly, but can't help me. When he starts win with the parameter myprg.exe, his DosBox windows is being resized, but e.g. the size of the characters or icons stays, so he can see the top and the bottom of the longer windows of the prg. We tried to use his .conf file on my machine, but it doesn't work either. However, it's not so surprising, because he has other video card and better monitor. But his example shows, that DosBox can do what I want, so I hope it will be working soon.) I don't know, maybe it's not about resolution, I'm not so familiar with these stuff. I hope this way it's more understandable, so that you can help me...
Thanks a lot:
akkkarki
