First post, by BoyOfDestiny
I believe p4's would be the wrong choice due to the pipeline. Would it fair better on an amd then? However IA-32 or 64-bit? I believe amd's 64-bit chipset achieves 32-bit compatiblity via emulation... would this bottle neck the performance? Enough so that an emulator would work less efficiently than on a p4?
The question boils down to... for dosbox if you could choose a processor and chipset... Intel or AMD? 32-bit or 64-bit [amd]?
I know someone would reply just get a 486 and blah for $50. I'm just planning an upgrade, and I would hope to gear a computer to my use, which primarily is emulation when it comes to gaming.
Thanks to those who reply,
