First post, by eadmaster
the cmdline version of fluidsynth has this "--chorus" switch to turn the chorus on or off.
Is there a way to turn the switch off in dosbox.conf?
Reply 1 of 1, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
DOSBox does not handle Fluidsynth directly.
If you are using a built with Fluidsynth support, contact the one who made this build.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
