First post, by basilhs_s
good evening everybody. i want to invoke an exe file wihich will translate a file from 737 to windows greek character set. The command i used in dos was
437to928 input-file output-file
i created a batch file in windows 8 which contains the following code
C:\dosbox\DOSBox.exe 437to928.exe 1.txt 0.txt
exit
where 1.txt is the input file and 0.txt is the output file.
unfortunately the 437to928 prompts to give both the input and ouput file at run time.
i have installed dosbox in the c:\dosbox catalogue.
what am i doing wrong?
thank you very much
