First post, by Too much memory
Too much memory
Offline
Hello. I tried to play Ultima VII Black Gate with DosBox. The DosBox window then said that in order to play Ultima VII, I should remove all EMS Memory Managers. I'm using Microsoft XP Home Edition...I haven't used memory manager in veeery long time so I don't know what to do. This may have to do with the config...but my tech skills are at a minimum 🙁
Thanks.
