First post, by paulm64
Hello, I've done some searching but I can't find anything that seems to describe my problem. When I try to go full screen on my Lenovo L420 running Windows Vista Home Premium 32bit, it goes full screen but the screen doesn't update. I can hear the game running (any game) in the background but the screen stays frozen as the same as it was when I pressed ALT-ENTER. If I ALT-ENTER again it goes back to a window and the screen starts updating again and the game plays normally. Can someone please help me with this? Thanks.
Paul
Reply 1 of 10, by DosFreak
Change output= in dosbox.conf to a different value.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 10, by paulm64
Thank you SOOOOO much! That did the trick! I tried several setting and ddraw worked the best. I'm so happy to be able to play epic pinball again and in full screen on my laptop! I owe you a beer!
Reply 4 of 10, by DosFreak
If you've tried all the output options then your only option is to upgrade or downgrade your video drivers.
Hopefully you are changing the right dosbox.conf
Reply 5 of 10, by Dwade
so after reading your reply i did some more looking around and found THE conf file but windows wont let me open it without downloading a new program. the file that i was changing was the DOSbox 0.74 options which is a batch file but when i open it it comes up in notebook and the first line says this is the configuration file for dosbox.
Reply 8 of 10, by collector
The dosbox options link should open it with Notepad, but it is the dosbox.conf that you want.
Reply 9 of 10, by Dwade
ok so I'm pretty sure im doing it right but still nothing in fullscreen so what is involved in changing my video driver or should i just be changing the screen resolution or frame rate. i dont know but i thank you for taking your time with me
