Mouse Movement Bugged (Dosbox Daum)
Reply 20 of 26, by SedrynTyros
ykhwong wrote:
Yeah, KB2908279 does the trick you just need to manually add the DOSBox.exe as described in the main article. Thanks for pointing in the right direction!
Reply 21 of 26, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
SDL people are loath to change anything in SDL 1.2x... They want everyone to move to SDL 2.x
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 22 of 26, by SedrynTyros
Darn ... well, maybe ykhwong could switch to using dynamic libraries for SDL? That way people could manually substitute the SDL.dll that work best on their system? I don't really understand the problem well enough to know what the best solution is; just thinking out loud, really.
Reply 23 of 26, by Great Hierophant
SedrynTyros wrote:
Qbix wrote:
Not really a solution for an official dosbox release though.
Well, it looks like the problem has to do with SDL so perhaps the SDL devs will address the issue.
Don't count on it. The last version of SDL compatible with DOSBox is 1.2.15, and the SDL developers are only active in developing the SDL 2.0 branch, which is incompatible with DOSBox.
I'm interested in knowing what version of SDL 1.2 was used for the official DOSBox 0.74, how it was compiled and why it does not have this problem in Windows 8.x.
Although SDL 1.2.14 was the latest version, released 10/12/2009, when DOSBox 0.74 was officially released on 05/12/2010, DOSBox's SDL reports itself as 1.2.13.
Reply 24 of 26, by HunterZ
I would suggest that maybe DOSBox should be ported to SDL2, but the problem there is that it reduces portability due to the fact that SDL 1.2 itself has been ported to more platforms than SDL2 probably ever will.
Reply 26 of 26, by NY00123
I have a feeling that the SDL_cdrom API is close to standalone, so it can be extracted from SDL 1.2 if desired.
As for improving portability, I'm afraid that a good way to do it is adding more code. One example is targeting SDL 1.2 (for older platforms) and 2.0 (for newer ones) altogether.
