First post, by DR_MARK
Sorry for the very basic question, but...
Can someone please explain the format for adding command-line arguments
(e.g argc)
to the [autoexec] section of the DOSBox *.conf file that is run at start-up.
I have tried "-2" and "/2" and just "2" (by itself)
but nothing is recognized
and program starts without argument taking effect
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
I think you misunderstand it.
it's not for parsing command line from the dosbox command to the autoexec.bat section.
If you need that, you need to use -c
If you are on the otherhand are talking about commandline parameters to the application
[autoexec]
Hello.exe /2
Water flows down the stream
Reply 3 of 4, by IIGS_User
DR_MARK wrote:
Possibly the edit of the *.conf file, (to add the commnd-line argument), did not take effect
until the word-editor was exited, (which is strange!)
I'm sure you've saved the file before.
Klimawandel.
