First post, by rkpb1
Hello,
Love this project so first off really have to thank everyone for the hard work!
unfortunately when I print to a file with these settings:
printer=true
dpi=360
width=85
height=110
printoutput=printer
multipage=false
docpath=.
timeout=0
[parallel]
parallel1=file
I get random characters like the attached image. Any ideas how to get rid of them? any help would be amazing.
The reason I am using print to file is, if I print to the printer from Dosbox through an LPT1 capture, it just gives me a blank page.
    20.04 KiB
Reply 1 of 9, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Well, Dosbox itself doesn't support printing, you need to give more information
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 9, by Dominus
DOSBox Moderator
Operating system, program name,
Maybe then someone might be able to help
Reply 5 of 9, by Dominus
DOSBox Moderator
Apparently it does exist or you wouldn't be able to use it 😉
XP 64bit is not really known for good compatibility, maybe try a newer Windows (maybe you have access to one and you can try the nonexisting program on that)
Reply 6 of 9, by rkpb1
ha, well i meant today it does not exist nor has support. It's called "Paging System 3.0" Internet Business Computers, INC (1994).
Reply 7 of 9, by Jorpho
MB6 is out-of-date; you should try the SVN Daum verison.
I suspect you have configured your program to use a printer standard that is not compatible with the standard used by the virtual printer. The documentation suggests that in Windows you should select "Generic ESC/P 24pin wide" or "Epson SQ 860".
