First post, by Sammy
I've Installed Win95 to Dosbox and use Voodoo Emulation (not a wrapper)
But ist was very slow...
Then i figured out that it renders in software Mode.
When i Change to Opengl then Dosbox crashes with an OPENGL Error in Status Window at the Moment the Game Changes Resolution.
When i set "Voodoo" to "Software" the Game works but very slow.
When i set "Voodoo" to "opengl" and output to "openglnb" Dosbox crashed.
What helped for me:
Set "Fullscreen" to "true"
And maybe use Fixed Resolution for Fullscreenresolution like "800x600" "1024x768" etc.
You can also try to set your real Graphicscard to the Resolution you set in Dosbox e.g. (800x600) before starting Dosbox.
I use the Following Settings:
fullscreen=truefullresolution=1280x1024output=openglnbvmemsize=4memsize=256core=dynamiccputype=pentiumcycles=maxvoodoo=openglglide=emulfb=fullsplash=true
I usw this on Dosbox3829 Daum Build.
Works very fast now, playing Colin McRae Demo like on the Real Hardware.
The latest Build from ykhwong.x-y.net can't start my Win95C Installation... it says "Windows Protection failure. Please Reboot"
