First post, by coltrane
When you take some screenshots from the gamesin DosBox, the screen becomes flattened, with wrong aspect ratio. If I try to use any photo editor to fix that, the image loss it´s original pixel quality/definition. Is there any way to fix the screen capture engine, so we could take screenshots as they really looks in the monitor display??
Thanks in advance.
Regards,
RColtrane
