First post, by coltrane
Sorry about my lack of knowledge on this but what is an opcode? Is it too hard to fix/implement?
Thanks for reading.
Thanks for reading.
it's an instruction for a processor (the heard of your pc) to process.
Water flows down the stream
Opcode: Short for Operation Code.
An processor instruction usually consist of an opcode + some data used in the instruction. E.g. the instruction to call a sub-routine, consist of the CALL opcode + the ADDRESS of the sub-routine.
MiniMax
_________________
Kindof like the available commands on offer? Like commands in DOS (cd,copy,del etc).
Two stones, two crosses, the rest is just icing. - 7th Guest
Thank you all for the explanations. I´ve asked it because DosBox is showing me the following message, right after my game crashes and exit:
EXIT TO ERROR: CPU:GRP5:ILLEGAL CALL 7
I presume that this could be caused by one opcode not implemented yet. This one in particular could be fixed? Or do you need more info to solve this issue?
Thanks again.
Rcoltrane.
As written in the errormessage:
ILLEGAL call.
This isn't a valid opcode at all.
Probably some code goes wrong and and interrupt tables becomes cs:ip => leads ultimately to that error.
As Quoted from our faq:
he CPU emulation encountered an instruction it doesn't emulate yet or and illegal instruction.
This can mean the game uses some advanced CPU functions not emulated yet or something goes wrong and non-code gets executed.
All in all nothing you can do anything about but wait for a newer version.
