First post, by S250
I just found out,whatever kind output mode you choose,snapshot only take the original display size.
is it possible to snapshot the opengl display and overlay display?
BTW:the offical release's overlay mode look difference with the CVS version.....
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
well we don't make the cvs snapshots you use 😀
and you can scale the images yourself with any good graphics program
scale2x has binearies as well to scale images.
Little use for dosbox to do that as well.
Use the proper tool for the proper job.
Water flows down the stream
