Gamepad not working
Reply 20 of 24, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
this is a config "problem". Debug Dosbox has most likely another config and thus is not pointing at a wrong mapper file. Make sure your config point at no mapper file.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 21 of 24, by mgman
Left all "mapperfile=" as blank, seems to have done the trick.
Thanks a lot for the help, everyone 😀 Since this has been an unusual case, there's a slight chance I'll run into a gamepad problem again in the future. I hope not, though.
Reply 22 of 24, by Dominus
DOSBox Moderator
just remember the one rule, generally you don't need a mapper file. If you have one without needing it, get rid of it 😀
(I dimly remember there being a reported problem with mapper files and joysticks...)
Reply 24 of 24, by Mils
Sorry, I know this thread is old, but I think this is an important issue that many other people may have and I want to express my gratitude to Dominus and mgman for solving it. I, too, had a problem with my joysticks not working in D-Fend anymore (while all of them worked in Windows). I thought I tried everything. It's 02:45am here and I was struggling to stay awake and fix my problem by searching on this forum when I stumbled upon Domino's post about clearing the mapperfile entry. It works ! Well, actually, merely deleting the "mapperfile=" field wasn't enough because the link was regenerated every time D-Fend started up. So I deleted the mapper.map file.
Thank you so much 😘
