First post, by lucky7456969
- Oldbie
Guide: Windows 95 / 98 inside Dosbox - Network over WLAN in Windows 7
I have given the Loopback adapter an MAC address (Private Range as suggested in the configuration file)
Should I give this loopback adapter a static ip address or should be dished out from my router (DHCP server).
For example my router is on 192.168.0.x and subnet mask is 255.255.255.0
Should my wifi adapter have a static ip address also?
Should the bridged adapter have a static ip address also?
on my dosbox emulator, I have set it some static ip in both clarkson telnet and trumpet winsock, called this 192.168.0.108....
You have no choices but assigning static ips to them.
Currently I am having a problem like this.
Which device has conflicted with the Ethernet hardware?
Thanks
Jack
