First post, by sndwv
I hope someone with a similar setup can help me out:
I have a NAS (DS214) set up as an iSCSI target for a single W7x64 PC. My intention was to mount images of my DOS games' CD's from there to use in DOSBox. Performance however, turned out to be horrible: there are constant hickups and hitches during any sort of video or (CD) audio playback, but basically during 'everything'. Mounting the exact same files from a local drive works just fine. The NAS' performance itself is great otherwise, reading and writing at ~80-110MB/s, which should be more than enough for this purpose.
The NAS is connected via a quality GB switch and short (0.5m & 2m) cat. 6 cables. The iSCSI target is mapped as 'local drive' X:, so I have my DOSBox' C: mounted via mount c x:\[stuff] and images via imgount d x:\[stuff] -t iso.
Are there any know issues? Should I configure something specifically/differently for this setup? Is there just some network overhead that can not be worked around?
Any help is greatly appreciated!
*edit: this is the same on 0.74 and SVN r3876.
