ykhwong's latest build?
General information and assistance with DOSBox.
Postby kalirion » 2015-1-06 @ 01:17
I wanted to download ykhwong latest build, but his site seems to be down - http://ykhwong.x-y.net/. Does anyone know if there's another place to find it?
Alternatively, any other good DOSBox builds which have good support for direct3d filters (or at least openglhq)?
kalirion
Re: ykhwong's latest build?
Postby kalirion » 2015-1-06 @ 01:29
truth5678 wrote:http://www.emucr.com/2013/05/ykhwongs-dosbox-svn-daum-build-20130506.html
Thanks! This one seems even newer: http://www.emucr.com/2014/02/ykhwongs-d ... 40127.html
Is emucr.com a trustworthy site?
kalirion
Postby truth_deleted » 2015-1-06 @ 01:31
<link no longer requested>
truth_deleted
Postby ykhwong » 2015-1-06 @ 03:35
The website could be temporarily unavailable due to the maximum daily web traffic limit.
As I manually reset the traffic, it should work now.
ykhwong
Postby Stiletto » 2015-1-06 @ 05:33
kalirion wrote:Is emucr.com a trustworthy site?
Not 100% of the time. I have often heard about malware signatures reported amongst EmuCR downloads in general. Given the nature of emulation, it's possible some are false positives - but given their Chinese hosting, it's also possible some are not. Here's hoping that it was a problem in their past that they've solved.
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Postby kalirion » 2015-1-06 @ 05:53
ykhwong wrote:The website could be temporarily unavailable due to the maximum daily web traffic limit.
Awesome, thank you!
Edit: Would this be the right place for a bug report? Your build from this January has an issue with the GOG versions of Secret Agent and Crystal Caves - when the screen scrolls horizontally, the UI elements at the bottom stutter/jump around.
Merely replacing dosbox.exe with the one from http://ykhwong.x-y.net/downloads/dosbox/win/20140125.7z fixes the issue.
kalirion
Postby leileilol » 2015-1-06 @ 23:12
The site's back up and there is a January 3 2015 build available.
by the way, DOSBox is not for running Windows 9x
User avatar
leileilol
Postby Dominus » 2015-1-06 @ 23:15
ykhwong, where have you been? :)
User avatar
Dominus
DOSBox Moderator
Postby truth_deleted » 2015-1-06 @ 23:38
kalirion wrote:Your build from this January has an issue with the GOG versions of Secret Agent and Crystal Caves - when the screen scrolls horizontally, the UI elements at the bottom stutter/jump around.
Confirmed this issue. However, it doesn't occur in dosbox-x (July 19th build), so it must be a commit after that date. Also, the former solution is here to the shaking HUD problem: viewtopic.php?f=33&t=9753#p65004. So, assuming the current issue is related, then it should be a change to vga_draw.cpp, particularly in a commit that occurred after July 19th.
Edit: isolated the issue to this commit: https://github.com/joncampbell123/dosbo ... 74d2ba07b4. Removing that commit prevents the above issue.
truth_deleted
Postby Spaz » 2015-1-07 @ 22:32
I have an issue with this latest build. Some games no longer work correctly with General MIDI. The games start fine, but no music. I have tested several Doom engine games that all exhibit the same problem (Doom, Doom2, Hexen, Heretic). Managed to get music on Doom some times, but rarely. Other games like Apogee's Hocus Pocus and Wacky Wheels work fine with GM.
Both the regular DOSBox 0.74 and the last Daum build (Jan. 2014) work fine with GM. My setup is a Roland SC-55 connected with MIDI to USB adapter. But, this is probably not related to my setup, as I have also tested with the software based 'Microsoft GS Wavetable Synth' which shows the same problem. Anyone else having this issue?
For the time being I have reverted back to the January 2014 build.
Spaz
Postby truth_deleted » 2015-1-07 @ 23:14
Confirmed that General MIDI music will frequently not start (not initialize?) in Ykhwong's latest build (win32). This can be reproduced within a single dosbox session, even though "mixer /listmidi" shows a device active. Verified that the latest dosbox-x does not show this issue, and also ruled out SDL as a cause.
It may be worthwhile to examine any 3rd party MIDI patches, especially since the dosbox MIDI code was revised somewhat recently (by dosbox team). In addition, VS compiler optimizations could be turned off for ruling out the compiler as a cause.
truth_deleted
Postby ykhwong » 2015-1-08 @ 01:41
Thank you for the bug info and solutions.
I will look through the issues sooner or later.
ykhwong
Postby Myloch » 2015-1-08 @ 22:12
@ykhwong: nice to see you back here! I saw a new version is out: did you perhaps fix the frequency of ibm ps/1 audio emulation?
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
User avatar
Myloch
Postby Gamecollector » 2015-1-08 @ 22:31
By the way, is there a way to suppress all these DOS_AllocateMemory/DOS_FreeMemory messages?
User avatar
Gamecollector
Postby truth_deleted » 2015-1-08 @ 23:14
Myloch wrote:@ykhwong: nice to see you back here! I saw a new version is out: did you perhaps fix the frequency of ibm ps/1 audio emulation?
In the ps/1 thread you asked for a "change to the source code to customize the frequency". Is that correct? That way you could test which frequency sounds best, otherwise do you have a sample at the supposed correct frequency to compare against real hardware?
Is this the line which specifies the clock frequency which should be a variable?
Code: Select all
SN76496Reset( &sn, 3579545, sample_rate )
If so, here are untested changes (a guide) toward a user specified clock frequency:
Code: Select all
In ps1.diff
In class PS1SOUND:
Bit32u clock_rate = section->Get_int("ps1clockrate");
ps1.clockrate=clock_rate;
change:
SN76496Reset( &ps1.sn, 3579545, sample_rate );
to:
SN76496Reset( &ps1.sn, clock_rate, sample_rate );
In dosbox.cpp
Pint = secprop->Add_int("ps1clockrate",Property::Changeable::OnlyAtStart,3579545);
Pint->Set_values(0,10000000);
Pint->Set_help("Base clock frequency of the PS1 audio emulation.");
In ps1sound.cpp
add a line to struct PS1AUDIO
int clockrate
truth_deleted
Postby truth_deleted » 2015-1-08 @ 23:18
Gamecollector wrote:By the way, is there a way to suppress all these DOS_AllocateMemory/DOS_FreeMemory messages?
In dos_memory.cpp, there is a parameter to turn off those messages.
Change:
Code: Select all
#define DEBUG_ALLOC
To:
Code: Select all
// #define DEBUG_ALLOC
truth_deleted
Postby truth_deleted » 2015-1-09 @ 22:05
truth5678 wrote:Confirmed that General MIDI music will frequently not start (not initialize?) in Ykhwong's latest build (win32).
Tested further, but no solution yet. I think it would be helpful to test this issue on non-win32 operating systems. It may provide insight.
I was able to replicate this issue on win32 by building dosbox-x with the newest version of the mt32 emulation. It displayed the issue across midi devices, leading to the possibility that it is a linker problem or an obscure bug. I also noted an issue where sound initialization fails in EF2000, but that is probably a separate issue and not so difficult to identify.
Edit: reproduced above issue in dosbox-x builds as far back as 1/22/14, before Ykhwong's properly working build from 1/27/14. I conclude that this is a linker issue (combined with early source code changes) which is causing the unreliable starting of midi music in some games. I can't confirm this yet, but it provides a guide so others save troubleshooting steps.
truth_deleted
Postby Myloch » 2015-1-11 @ 00:14
truth5678 wrote:In the ps/1 thread you asked for a "change to the source code to customize the frequency". Is that correct?
That was an old post, a user found the technical sheet of the audiocard and after some private messages with jmk, we concluded that the source code needs to be changed from this:
To this:
SN76496Reset( &ps1.sn, 4000000, sample_rate );
I informed ykhwong about it one year ago however I don't know if he finally changed the code in the new build
User avatar
Myloch
Postby truth_deleted » 2015-1-11 @ 00:27
The Great Hierophant suggested that clock frequency a couple of years ago:
The lowest frequency the chip can output using the 3.579MHz clock is 874.76Hz. Perhaps a comparison of the raw Silpheed music data would be instructive. Might it be that the PS/1 chip is using a 4.00MHz base frequency?
Has this clock frequency been verified by an expert like Great Hierophant? I'll check his blog because he has made available his knowledge of these kinds of devices. Otherwise, here is part of the pseudo-code which I posted above to implement a variable clock frequency for testing:
Code: Select all
to:
truth_deleted
Next
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 4 guests
