First post, by Rob
can someone please explain to a computer illiterate person (me) in plain english how to get a game to run with this? i have read the readme a bunch of times and i just cannot make any sense out of it. thanks in advance 😊
Good day.
I will try to keep it short. In order to use DOSBox you need to mount (=enable) as may drive as you need (as well as their type). You also need some basic MS-DOS knowlege such as getting directory contents, to know what executables are, etc...
Take for example gamex is going to be installed from floppy (commonly A: drive) to a folder (they were called sub-directories in the ms-dos days. That stupid folder "name" is just a Microsoft idea) named, you guessed it, GAMEX on drive C: (Your hard-disk). So for starters, we will need at least two operating drives, the A: floppy where we are installing from and the hard-disk (drive C:) where we are installing to. You see -> Source (floppy A:) --> Destination (hard-disk C:).
Z:\>mount a a:\ -t floppy
Z:\>mount c c:\
(These two commands will mount drives A: and C: respectively).
Z:\>A:
(a drive letter followed by a colon, actually CHANGES to that drive)
A:\>dir
(to get disk contents displayed, REMEMBER: Executables files for ms-dos could be anything with .bat, .com or .exe extension). Let's assume there is a INSTALL.BAT on our floppy.
A:\>install.bat
(This will launch the installation program. Follow its instructions and tell it you want to install your game to C:\GAMEX - Usually the sub-directory (folder) will be automatically created if it does not exist. NOTE: You can create folders with the MD command (Short for MakeDirectory).
Now the game it's installed to the specified location -> C:\GAMEX
A:\>C:
To change to drive C: - We want to run it from there. Floppy is just used from reading source data.
C:\>CD GAMEX
CD -> ChangeDirectoy, allow us to "go" to the selected directory (folder). This is where we have installed the game earlier.
C:\GAMEX\>DIR
(again). Let's assume there are a "suspicious" PLAY.EXE in there.
C:\GAMEX\>PLAY.EXE
You got it...
What actually do you want to know?
What about readme did you not understand?
ok first of all thanks for taking the time to help
i have managed to get my cd drive and my hard drive "mounted" but when i put the alone in the dark cd into my computer and type dir in d:> and then type "install.exe" i get the intallation screen but its all messed up and doesnt seem to work at all, alone in the dark is one of the games its supposed to be compatible with. any ideas? thanks again
ok iv managed to get it installed but now i keep getting the message "Error: CD not found No cd-rom driver"
wrote:ok iv managed to get it installed but now i keep getting the message "Error: CD not found No cd-rom driver"
When do you get this message? During installation, or when you start to play the game?
MiniMax - "I want details, details, DETAILS!"
_________________
Try the mount flag '-t cdrom' when mounting your CD-ROM drive
mount d d:\ -t cdrom
That should get you a CD-ROM driver.
Also, you may need to specify a valid label. Ex.
mount d d:\ -t cdrom -label AITD
To know the label, check My Computer or do a VOL D: command at a dos box.
WOOHOO I GOT IT WORKING! 😁
thanks for your help everyone 😁
i have been waiting for this program all my life 🤣
1 more quick question, how do i make it fullscreen? thanks
Alt-Enter
or
fullscreen=true
in your dosbox.conf configuration file.
thanks 😁
